where to get ABS fixed?
r1200rt
uk
2007 R1200RT (non servo model)
ABS packed up, possibly "Stuck brushes"
brakes still work ok
any idea where in the SE UK/London i could get this fixed?
In the comfort of your own garage, have you tried a light tap with a toffee hammer to free the stuck brushes
repeat - light tap with a toffee hammer, not belt 7 bells out of it with a 4lb lump hammer ....
im not even sure where the abs pump is
tank off? mm.. sod that, will just live with it!
do you have a GS or an RT ?
RT might be easy - my K1300GT was just under the faring side panel - 30 mins vs 5 hrs
the tank comes off easy on a GS its the rest of the crap
2007 R 1200 RT ,,,,First Post
As far as I’m aware if it’s a non servo model there’s nowhere to tap wit a hammer. JJH
Just reading the advice on here it’s the servo that gets the tap. Others suggest that tapping causes terminal damage. But with a non servo model there’s a chance that someone know how to easily sort it. JJH
You have to tap the electric motor on the modulator. (Non servo).
