garry a
Today started ok. I started the trusty 2002 1150 to check the battery was ok and left it running in workshop. Then it all went wrong ! Got a bit side tracked and forgot about it. 3 hours later remembered. Found the bike sitting in a pool of oil not running the oil level window has melted and got blown out and was 10 ft away even the plastic nut covers no front swing arm fell out with the heat
. So need to get bike up and running for dragon rally next weekend.popped over to bmw got a new oil window fitted that changed oil filter as I had one filled it up with oil still had quite a bit in it .Got it cranking over now. But no spark ! Ignition on fuel pump runs then stops as normal,put in gear turn engine with back wheel nothing no fuel pump so I'm thinking it has fried the hall sensor.Any ideas please .and quick
) had a discussion & a few photos showing similar damage to yours and apart from replacing the spyglass and HES no further major damage was reported.
