Wider foot pegs
Captain Black
manchester
Anyone recommend after market pegs for PD ?
The OE ones aren't the best comfort wise, to narrow.
Black would look good as well.
Ive these fitted to both of mine. But like anything there's a compromise. To get the gear change to work properly the threaded adjuster is right on the limit
That's the sort of peg, the OE is crap.
Why the big deal with the gear change ? Those pegs are how much further back ?
I have the same ones - they are further back AND lower so the gearchange (and brake lever on mine as well) needs to be adjusted....
I have $15- Parts Unlimited Yamaha YZ Wide pegs on mine and they do the job.
They slide straight in to the mount but the pivot bolt, stop and spring stops need to be hacked around a bit. An hour or two with a drill, hacksaw and file should be ample.
There is nothing that special about the width and angle of the OEM pegs so there are probably a few others that can be made to ft too.
Not many kids ride WR 500 s .
These red numbers alongside the dimension lines with mm after them are actually the sizes in thousands of a metre, and at 80 x 50 the foot pad is similar to most
aftermarket wide rests.
I used Pivot Pegz on my R00GS they fit and i find them comfortable - but not cheap
I have the Motobau ones which are ideal if you have big feet.
Anyone happen to know if the 1100 GS footrest mounts have the same spacing and offset as the 100 GS?
I ask because I'm interested in a set of these from sw-motech and because thet cant supply the ABE paper for the R100 they wont commit to saying they fit
Ta.
I've just put a pair of r1200gsalc ones on an r100gs they fitted like a glove!
