Will it won't it start
PW Cymru
Moderator
Moderator
Nr Cardiff
Well going to press the on button tonight and see if it starts, it's only been a year :eek:
Time flies, but haven't had as much spare time as I thought when I bought it.
Fit the rocker covers back on and the tank overflow tube then give the button a push oh and a bit of petrol should help too.
I'll keep you posted.:D
Good luck Paul :thumb2:thumb2
The R90s fired up sweet as a nut. so yours ought to do the same.
watch out for Carbs overflowing as it's a common problem after rebuild, "sticky" or miss set needle valve.....
He shoots he scores.
All sounds good, starter motor worked well after rebuild (no bushes in the bendix:eek:) and turned over nicely, battery is still strong after a year on charge:D.
Left hand carb had a slight drip but stopped after I took it for a run.
Gearbox is sweet, thanks Rob:thumb2, I still owe you lots of beer.
Tick over is a bit lumpy and needs to be sorted.
Rear brake bled and now works well enough to lock the back wheel.
All electrics seem to working well (lost the rear lights on the M6 when bring the bike home in the dark-scary).
I think I'm going to enjoy my Sunday runs on this one.
Now for the MOT
Now for the MOT
And where's your video of the beastie running, eh? :rob
I don't do video, I haven't even got sound on my pc.
It just stopped one day.
Best I can do for now.
It's all there just thought I'd leave the lowers off while I continue to fettle it through the winter.
Still plenty of little jobs to sort out.
