Wireless help, please!
andysdad
Northampton
Just got a new router; every time I open my laptop from Standby the wifi loses Internet (but not local) connection.
If I go into Networks and disconnect then reconnect, the Internet reconnects.
Reloaded settings, key etc. Using Windoze Vista Home Premium.
Anyone got advice, please?
Thanks,
A
Disable any dial-up services you might have installed on the machine.
IIRC it's a Vista problem.....
any chance of upgrading to 7?
Also happens on my HP notebook which uses W7. It appears to be a power saving issue. Google offers some workarounds, the simplest of which is to disable the wireless adapter and then re-enable in the device manager.
Still happening
Any ideas please?
And no "buy a Mac" comments thank you!
A
short workaround is to go into the power settings and configure it to switch off the monitor off after a given time but disable standby and hibernation. Not perfect I know and if it was me I would leave all settings on "never" when plugged in
and as for the fatuous mac comment go and read this
http://forums.macrumors.com/showthread.php?t=518958
had the same problem,thought the router was knackered so bought a new one.still had same problem so googled it and came up with the power saving problem,went through the process stated above and its kind of fixed it but occasionally i lose internet still so i have a LAN cable in connected to my router and i just connect the laptop to that and go make a coffee,when i get back i unplug the LAN cable and its all sorted.beyond that i have no idea whats up with it.im using vista too.
Still need help
REDCASTLE - thanks for the tip but it's a laptop and the battery has just died too. Really need a proper fix.
LOVED the Mac link = they think they are SOOOO perfect!
Aspiring - too far from the router to plug in. Thanks for posting though.
Any more ideas out there?
A
I have a similar issue and am with Sky broadband. Never used to happen but started doing this about a month ago.
I can connect to another local wireless connection (they have not protected their net!!) and it does not happen or does not appear to happen.
Just living with it at present.
