Wonder wheel and Nav 4
MondoRich
Scotland
Good evening, yes there’s still some of us with a Nav |V out here 🤣 R1200GS MY14
The wheel just used to toggle between a data screen and the map and has stopped working.
Anyone else experienced this? Any cures or is it just another electrical failure albeit after 8 years?
I’ve done a hard reset on the nav but no change and it’s £140 for a new wheel so if I’m going to spend that I’ll get a Nav V too and some more functionality.
Is it the same Nav cradle that BMW supplied for a |V and the V?
Is it the V| that has a different cradle?
Thank you 👍😀
Mine stops working from time to time and the problem is never at the wheel. I found that if I give the Nav mount connections ( the brass pins ) and the Nav brass connector on the back of the Nav a good clean, then it would start working again. My bike lives outside under a heavy cover and it can get quite dusty down here, so I think it is that that is causing my problem's. I hope it sorts your bike out too, as its an easy fix.
I've also had this problem and was advised by a top man on here to do a software update on the Nav V and that cured it.
Stu
Hi Rockred and thanks - anything special to clean the pins with?
Hi DrRich, nothing special, just something that will clean the contacts up so that it makes a good connection.
I use the wife's toothbrush and a little electrical cleaner sprayed onto the brush... (also good for getting dog shit out of the hard to clean pattern on the soles of my trainers). Always give it a good wash after use though...and sneakily pop it back into the bathroom, she's never noticed yet.
Sent from my SM-G981B using Tapatalk
