Xenon HID Headlight
bsa250
Wadebridge Cornwall
Hi Folks,
Anyone familiar with an intermittent problem I am having with Xenon
headlamp ! just recently purchased an Autocom intercom and needed an
additional blue-tooth device to make and receive phone calls, when pressing
Zumo gps device for use, today it switches my xenon headlamp off very
strange !! pressing headlamp\flasher fails to turn headlamp back on, only way
to do it is to turn off engine and restart !! I recently installed a new battery
so thats fully charged.
Some times it will work fine and xenon light stays on but problem as I say
intermittent ?
Many thanks Mack....
This is likely to be a break through problem. are the devices close to one another? If so try and move them as far apart as possible.
It could be that your HID is on it's way out.
You could try disconnecting and then reconnecting all the connectors to both HID and Autocom incase you have a poor earth and something is acting like an aerial.
Failing this then try wrapping the HID ballast unit in tin foil. Not much more can be done really, distance and screening might cure problem.
Hi Ian,
Thanks for your input, I will check it out and try the above mentioned
Best Regards Mack....
