Maintenance...or lack of it
It turns out that while this bike looked immaculate on the surface, it has not been well maintained since it was built.
While fitting the new Hyperpro shock, and new chain/sprocket set (I have a question on that later), I found that the grease in the roller bearing at the bottom of the shock has actually gone solid and the bushes in the other 2 joints had seized. See photos. 1 is a little difficult to make out.
First the new shock and reservoir mounting-
Bottom mounting point...if you look at the top you can see what is left of the crease.
Anyway, after re-greasing, replacing the rollers, turning the bushes in a lathe and reegreasing those, everything was swivelling as it should
Next came the chain and sprocket set. The front sprocket was so warn, it looked like pins poking out of a metal disk. I forgot to take a photos, but will try and dig it out of the waste bin next Saturday and show you. Never seen one that bad before.
The question I mentioned earlier.... this is our first Yamaha, is it normal to have press fitted spacers in the rear sprocket on Yam's? Never seen that before. Though maybe that's because I don't get out enough
Anyway, I made a tool and changed those over to the new sprocket reasonable easily, so no problem.
This is the bike with it all fitted.
All being well, it appears that the rack will get powder coated after all. I will post photo of the finished and fitted item next weekend.
As you can also see in the photos above, the Mitas E09 is also fitted now, though still waiting for the front to arrive. This rear tyre is a 110/80-18. Rather small, but it looks right on the bike and gives much better clearances and suspension travel.
Looks like we're on schedule to have it ready for a trial run next weekend.
