Joybringer
Thanks, ned-diddly-idlly.
It seems it does work, despite the manual (that I can see
) not referring to it, and neither the UK or US tech support peeps knowing about it. The UK one even put me on hold, while he 'investgated' it. I suspect he couldn't find his ar5e with both hands, but hey ho...
Anyhow, it only works when the turn icon is in the top left corner, as 'rob mac' kindly revealed. If you tap the top left without it there, it just brings up the list of directions, but no repeat voice commands.
That's where I was going wrong - previous Garmins repeated the 'searching for satellites' and 'ready to navigate' voices, whereas this Zumo only repeats valid turn directions/instructions once you've set a route, and consequently, when I've been testing it, I haven't waited for the turn icon, or even moved off the sofa
I am indebted to you all, thank you
) not referring to it, and neither the UK or US tech support peeps knowing about it. The UK one even put me on hold, while he 'investgated' it. I suspect he couldn't find his ar5e with both hands, but hey ho...Anyhow, it only works when the turn icon is in the top left corner, as 'rob mac' kindly revealed. If you tap the top left without it there, it just brings up the list of directions, but no repeat voice commands.
Yonkyo, where did you get that tinted adv screen from??
