Announced waypoints - Tyre - change to shaping points - NAV 5
peter56
darlington, england
Been for a ride today and I have a route in my nav5. This is the first time I followed a planned route which I downloaded from my PC. It keeps showing a message (Approaching) for a few seconds. This must be a waypoint or shaping or via point how do I stop this from happening :confused:
In basecamp, if you left click a waypoint you can de-select the “alert on arrival” option. That’ll do it.
I understand this is also the way you change a “waypoint”into a “shaping point”
Tyre creates announced points on my Nav V, it’s doin’ me gourd in
There are several ways. Here are some:
Turn the sound off
Make the waypoints, unannounced shaping points. You can do that within the Nav V itself
Use BaseCamp or Mapsource, instead of some other shonky non-Garmin software
Ask in the Tyre forum or of Tyre themselves, they make the stuff. See sticky no.2
don't see anything in menu of nav5 to do this will check tyres forum
Home screen
Apps
Trip planner
Tap on route
You should see a screen that shows from the left, three horizontal bars in the top left corner, a list of the points of the route, starting with your start point with a green flag and a series of orange flags. On the right the route’s name, its distance and travel time, map and go buttons.
On this screen, beneath the green flag start point, there’s the series of points with orange flags. These are the announced waypoints
Tap on the three horizontal lines
Tap on Edit Destinations
Tap on all of the orange flags or as many of them as you want to change
The orange flag(s) should change to a blue dot
When prompted that the duration and arrival times will be removed, change to shaping point? Tap yes
Tap Save
You may well see the device recalculate
Tap the back button
You are now back on the screen with the three horizontal bars in the top left
Check total distance, travel time and tap on map. Does the route on the map show a green flag, blue dots for the shaping points and a cheques flag at the end? Does it all look right? Yes....
Tap on back button
Tap on Go!
Job done.
PS You can change all or any of blue dots back to announced point orange flags using the same method
wapping again thanks for reply.
Have tried your suggestion . In the list it starts with green flag then blue dots and a checked flag at destination. However when I view route on map it has created lots of orange flags. I am at home and running it in simulation and it still says approaching
When you say you are viewing the route at home, are you saying that:
1. You have changed all all the intermediate orange flags to blue dots within the device (as above) and saved it to the device
2. That when you view the amended route on the device’s map it has a green flag (start) chequered flag (end) and blue dots in betweeen, replacing the orange flags
3. When you view it at home, I guess on a PC, the points in between are flags?
What software are you using to view the route on your computer?
Are you sure you are looking at the amended route on your computer and not the old version?
1. the intermediates were always blue within the device route list.
2. but view route on device map. it shows lots of extra orange flags not put there by me.
3. when viewed on PC tyrestotravel all's well
have been able to clear all the orange flags in the map view of route by changing the vehicle to a car then it recalculated. Running it in simulation all looks good :)
The problem would seem, as is so common, that you are using two different pieces of software to perform one function. Tyre, a third party route planner and Garmin.
If you can persuade yourself to limit to just one (either Garmin’s BaseCamp or Mapsource) you’ll be reducing the chances of bugs and errors creeping in.
looks like I will have to master Garmin’s BaseCamp not a fan. I love the street / satellite view that comes with tyres
