Thank you Thomo. The 700 does not have that 'V' cut in the beak, quite the opposite, it has a slightly raised middle section. The camera would be very obvious and more prone to theft or criminal damage if mounted in the same position.
My mate has the camera system on his GS. It has been fitted just above the o/s indicator using the bracket and fastened using the same bolt which holds on the indicator stalk.....looks brilliant
