Autocom speakers in a TourX
GS TRV
Belfast
Anyone have a foto or two of how they've installed their Autocom speakers in a TourX? I've just popped them in behind the cheek pads - the fit is good but have noticed a considerable drop in volume :(
Just a living room test with IPod up to max volume and with control unit to max but sound is clear but level is a bit subdued.
There's plenty of space to install but no matter where I velcro the speakers they are invariably behind the pad which obviously absorbs a lot of output. Bit of a bugger to sort - if anyone has a foto or two - I'd much appreciate it.
Trev :thumb2
Trev
Don't install them behind the pads, take the pads out and remove the covers, there is a recess you fit them into on the actual pad and then refit the cover.
It can take a couple of attempts so the speaker is right beside your ear but as the only thing between your lug and the speaker is the blue cover you won't find any problems with volume. :eek:
Trev same as above, Autocom fitted them that way for me at the NEC on a new TourX
Spot on guys :thumb2
no shortage of volume now :eek
next phase - how did you fix the audio cable that comes from the helmet - other than trying to wedge it between shell and lip I can't see any other alternatives :nenau
Wedging it is the method that seems most common, never seen it done any other way.
I did use some duct tape to keep it tidy against the shell though. :mmmm
Trev
Do you actually fit them to the cheek pad under the cheek pad cover ??
I just put mine in the recess where the cheek pad meets the rear padding, if you see what i mean :confused:
got to take it apart today to fit the open face kit for the mic, so might have another look and maybe take some piccies for comments :D
just fitted the mic kit and now put the speakers behind cheek pad covers
if you follow the Arai fitting guide within our kit or headet instructions this will give you a clearer idea of how we fit the headsets into Arai's. the only difference is that we fit our open face conversion kits onto the mics to protect them more from the wind due to the style of the lids
rich :beer:
Well been out today with the revised setup, VOX control was spot on with the open face kit fitted.
Volume was fine when speaking at all speeds (legalish) however the IPOD music could not be heard on the move and very low at standstill even with the ipod at max level, when I got home I tried another IPOD which was much louder and needed the volume reducing alot.
After investigation into the 1st ipod I found in the settings that the max volume level was cappedset at about 1/3 of maximum. This was set back to max and now both Ipods have the capabilty to blow my head off :blast
the autocom rocks :thumb2
So the moral of this tale is check your settings on your ipod aswell :o
rich :beer:
Rich
What does the open face conversion kit consist of.... I could probably do with one as I get a lot of interference from the wind.
Chris
Rich
Chris
Part No 1198 Open face conversion kit. One kit converts two helmets.
Fitted this after receiving a recommendation from Autocom to the Tour X and it does make a difference.
Basically it is an extra foam cover and currently listed at £2 so very cost effective. :thumb
Rich
Chris
looks like mine in the photo above when its fitted, trust me it works a treat, my vox was constantly activating before it was fitted:thumb
Damn!
rich :beer:
I knew I should have kept the instructions after I fitted my system!
Can you download the fitting instructions for the tour x?
Thunder
Do you know if I can order this from the Autocom website or do I have to find an authorised dealer to order it from.....:nenau
Chris
The mic is held in place by being behind the cheek pad mainly and bent to shape, the kit came with some sticky back velcro, I cut a small strip (which you see in the photo) just to help keep it in place. I might get some more photo's tomorrow if I get chance to show exactly what I did..
ref getting the open face kit, I got mine direct from autocom, only because the dealer I got the kit from is closed till the 11th :mcgun
Rich
Chris
well the ofck will consist of two velcro discs that will stick onto the back of the mics to make them one sided to prevent wind hitting the back of the mics, and 4 foam covers. one is fitted per mic to help tidy up the fit and to help disperse the wind a bit more around the mic. two or three spare covers all depending on how many mics are fitted.
Paulbde, if you download any of our kit instructions there will be a basic Arai fitting guide within them :)
Rich :beer:
Earplugs
perhaps a silly question but can you still hear music etc if you use earplugs wth the autocomm setup?
Good question :thumb2 I won't know until I install mine on the bike. The instructions do mention about using it with earplugs so it should be possible. I'd be interested to hear from anyone as well - any takers?
You can run the unit at a higher volume (how you change it depends on the model) and you can hear it, but I personally found a set of internal ear plugs from Green Leopard was the best solution.
