Viking Way/trail
Rob J
Peak District
Any of you guys heard of or riden this route?
if so I have a few questions :
1. Is it any good?
2. Where Start & finish?
3. How many miles?
4. How many hours?
4. any map source files?
cheers
Rob :thumb
is this it:nenau
The Viking Way is a long distance footpath in England running 147 miles (237 km) between the Humber Bridge in North Lincolnshire and Oakham in Rutland. The Countryside Commission recognised the significance of the Viking Way as a high quality long distance walk linking other major routes in Eastern England, these being the Yorkshire Wolds Way at the northern end, the Hereward and Macmillan Ways from Oakham and indirectly via the Hereward Way, the Jurassic Way from Stamford and the southern end of the Peddars Way from Thetford. The route almost entirely forms part of European path E2. Many pre-historic settlements were established on dry ground in the Lincolnshire Wolds and on the Limestone Heath. Sites of early settlements will be passed on the route. From the 9th century there is evidence that the Vikings were exercising their influence over the county. This is evident in the place names (ending in “by”), Scandinavian names recorded in documents and also names marked on coins. Significant parts of the Viking Way are classified as Byway Open to All Traffic (BOAT) and are used as vehicular rights of way.[1]
Contents [hide]
1 Route
2 Route Electronic Downloads
3 Ordnance Survey Maps
4 See also
5 References
6 External links
7 Gallery
[edit] RouteThe walk passes under the Humber Bridge, then follows the escarpment of the Ancholme Valley over the M180 at the A15 roundabout. It follows the Lincolnshire Wolds over the AONB through Caistor and Horncastle, where it follows the River Bain into Woodhall Spa. It heads north-west through Stixwould, Southrey, Bardney, Stainfield, before reaching Fiskerton where it follows the south side of the River Witham towards Lincoln due west. It used to run alongside the river on Waterside South and then down Canwick Road, but was diverted in around 2002 to take a detour near Washingborough over the river.
From here it crosses the Lincoln - Grimsby railway, then enters Lincoln on Crofton Road then skirts the south side of Lincoln County Hospital then follows Lindum Terrace and crosses the A15. It passes Pottergate and enters the grounds of Lincoln Cathedral, passing the south side on Minster Yard. It heads down Steep Hill and follows the main shopping High Street of Lincoln, over the River Witham and crossing the railway at a level crossing. It follows Tentercroft Street then along Sincil Bank towards the football ground. It heads along Scorer Street towards South Park, and meets the old route on Canwick Road (B1188). It then runs along the southern edge of the South Common, which also forms the boundary between the borough of Lincoln and North Kesteven and crosses the A15 on the North Kesteven boundary.
It runs parallel to the A607 to the west of Bracebridge Heath and through Waddington, Harmston, Coleby, Boothby Graffoe, Navenby and Wellingore along the Lincoln Cliff, then follows the old Ermine Street, crossing the A607. Near High Dyke Farm, just north of the A17 it meets the boundary of South Kesteven and North Kesteven. At Byard's Leap it crosses the A17 and follows the B6403 towards Ancaster along the South Kesteven boundary (which continues to just outside Ancaster). It heads west and enters South Kesteven. It meets the A607 again at Carlton Scroop, then crosses the River Witham and passes through Marston and Long Bennington. It was extended to Long Bennington in 1997 to allow walkers to cross the A1 on a roadbridge, as previously they were obliged to cross the road directly, near Foston. It no longer goes through Allington, and crosses the A52 near Sedgebrook and a level crossing over the Nottingham to Grantham Line. It then follows what used to be called Sewstern Lane and meets the Lincolnshire - Leicestershire boundary near Harston which it follows and crosses the A607.
It passes Saltby Airfield and Buckminster, then goes through Sewstern where it enters Leicestershire and the borough of Melton. It rejoins the Lincolnshire boundary near to the source of the River Witham then enters Rutland and Thistleton. It passes alarmingly close to RAF Cottesmore and goes through Greetham and Exton. It meets the A606 and Hereward Way at Whitwell, then passes through the two watersports centres on Rutland Water at Whitwell and Barnsdale. From here it follows the A606 into Oakham.
[edit] Route Electronic DownloadsGoogle Earth route map
Google Maps route map
Bing route map
Wikiloc route map
Every Trail route map
Route You route map
Trimble Outdoors route map
GPS eXchange Format
Memory Map route map
[edit] Ordnance Survey MapsThe Viking Way is shown on the following maps by Ordnance Survey:
Explorer maps 234, 247, 272, 273, 281, 282, 284
Landranger maps 112, 113, 121, 122, 130, 141
[edit] See alsoHumber Bridge
Lincolnshire Wolds AONB
National Trails
Long-distance footpaths in the UK
European Walking Route E2
[edit] References1.^ http://www.multimap.com/s/h7L3LnlF
[edit] External linksThe Ramblers
Coordinates: 53°41′50″N 0°26′40″W / 53.69722°N 0.44444°W / 53.69722; -0.44444
[edit] Gallery
http://en.wikipedia.org/wiki/Viking_Way
google is your friend :type:thumb2
Much of it is currently TROd:
I guess google didn't turn that up. ;)
Oh, and AFAIK the work has not been carried out, so expect the TRO to be extended, and extended and then made permanent....
i was down near where the tro notices are and the huge logs that were blocking the entrances have been moved,also a few bikes and 4x4 were using the tracks,the trailwise website makes no mention of the tro,that said i have not confirmed with the row officer whether it is open or not.of course i turned my bike round and went back the other way:D
