Braided stainless steel brake hose
Steptoe
Him/Bloke/Fella.
S/W London.
Full kits for your model of GS, lifetime warranty, ABS or NON ABS ,
clear covering or green, red, neon red, blue, neon blue, orange, purple, yellow or carbon fibre look -
Full set - front and rear ABS - £98
Full set - front and rear non ABS - £87
PM me --
custom sizes also supplied .
picture of ABS
Black carbon fibre look -
custom size for a customer - 22 inch master cylinder to solid line connection, so it fits with bar risers etc
How much difference to they make to the feel of the brakes ?
[I do like a like feel personally)
had a friend fit them to his GS with servo brakes - no problem at all
well one small one actually, which i will tell to those that buy a kit from me - :D :D
hey, business is business .
you can buy then from an accessorie dealer, or a fellow GSer who knows what problems you will encounter --
:D :D :D :D
just thought i'd give this a bump -
The kits include all the washers, and the fitting/banjo bolts in stainless steel -
Step
What's the difference between RED and NEON RED ?
Tx
Alx
Re: brakes
Kenny Rodkiss said:
Do they still retain the solid pipe that runs left to right across the fork brace?
Yes - and you get a new stainless "block" ( attached to the R/H side of the brace) that the pipes divert from -
Ah ha ! Four letters, eh ? Sounds like that could be the fellow for me.
Are you still doing these kits - as I am interested - what is the p&p on a full set of (clear) for a 2000 R1150GS ABS?
Hi Steptoe,
Is it possible to purchase just the custom one and if so how much? Also, would there be a problem in sending it to Italy. I have just purchased Nippy Normans bar risers and the brake line is too short.
Cheers Jay.
Steptoe - have you seen HEL's prices for their brake line kits?
I think they're trying to wipe you out!
The Hel website is quoting £123 for an 03 abs set. Steptoe is still cheaper is he not ?
Just ordered a non-ABS, two-line set for a French mate, £67:00 including carriage, obviously they messed up big-time,or did they?
The website does quote £49:00 for the 2 lines,though,complete with all bolts,washers,etc.
Steptoe, I'd like to convert to stainless, but I'm scared of trying to bleed my EVO ABS brakes.
How much including fitting?
ABS set cost £98 - they're the same lines as the servo -
should take a couple hours to fit - if they supply the correct fittings
