bess the newf
Hello
I am trying to work out what this http://youtu.be/-if_b377CfY noise could be.
i have done the basic 12 and 6 o'clock hands on rear wheel and wobble test, and there's less than a mm of play. There is no grinding or friction sound when rotating the back wheel by hand (like our man in Argentina).
I have done 18k kms on the bike, and it is a 2010 R1200GSA. I have done the servicing and changed the gear oil and final drive oil at 15k in the summer, and have not detected any leaks since.
Yesterday, i checked the gearbox oil and had to add about 150ml - that doesn't seem right.
The only reason why i started to investigate this was because i put the bike on the centre stand with the engine running to check the engine oil level, and when i put it in first I heard the knocking sound. Now, I am paranoid - i've heard so many stories about the final drives that I am scared to use the bike.
I would be hugely grateful if those with more engineering and mechanical knowledge than me (most) could have a listen to the youtube click and suggest some course of action.
regards
bess the newf
regards
bess the newf
