Hi rocks,
Unfortunately, to post a piccy I'd have take the whole lot apart behind the rear number plate. It's all sealed with silicone and tape so I'm sure you'll under if I refuse you that one.......
There are only three wires from the Lite Blazer.......The Instructions are dead easy, you still connect the earth as per instructions, just swap the other two.......if you get the Blazer, try it on a Battery first, you'll see what I mean.......
The Xenon is actually on the Dipped Beam not Main on mine.........and it's like changing night into day, just make sure it's set right for the load on the Bike.........
I have it set for two up so when I'm on my own, it is a wee bit low but the output is great compared to the original, then again, that's not to difficult is it!
'Iain L' thought that he had been flashed by a Camera when following me on the Sleepezzz weekend, we had passed a Phone box in which the light reflected into his line of sight.
He was behind me but the light was that bright he thought, briefly, that it was a Flash.........pretty bright then!
The Lite Blazer is stuck to the Touratech Mudguard with double sided sticky pads.
It came attached to an angled metal Number plate backing plate.
This would not allow me to fit where I wanted, so after checking with the Manufacturers, I removed the metal plate using a Hobby knife.
Easy to do, just be careful when you get to where the wires come out of the unit, by the time you get near there with the knife, you can simply peel the two apart......carefully of course.
The Sticky that it was attached with is easily cleaned off, just roll it off with your thumb.
All I did then was to drill a small hole in the Touratech Mudguard to pass the wires through to make a tidy finish to it all........Sorted...
HTHs
CC
