►►► 850/1100/1150 Oilhead info & tips
Not open for further replies.
Paul G (BHT)
ʝǟռɨȶօʀ
Administrator
ֆǟʟօքɨǟ
Oilhead Maintenance Manual
► Oilhead Maintenance Manual
Engine
► Why's My Bike Running Rough? A Common Fault.
► Adjusting rocker end float, and valve clearances
► Alternator belt change
► Changing a Cylinderhead gasket
► Corroded oil cooler connections
► StarterMotor Info
► Starter Strip
Electrical
► 1100/1150 fuse and relay. What and where!
Frame and suspension
► Fork seal fitting
Brakes
► Replace old brake hoses ASAP.
► A simple fix for some brake servo problems..
► Front discs loose/rattling?
► Have you an 1100GS? - You've a part needs checking for your safety
► HEL Braided Hoses (warning)
► BMW ABS II (Non-Integral) Disassembly and Analysis
► Intergral ABS Removal & Conversion A Great Youtube Guide (the old way).
► Servo/ABS problems
► Simple, NO COST servo removal of 1150 IABS system
Rear Bearing and Driveshaft
► How to check your Final drive bearing - 1100/1150
► How to check and replace the Final Drive Crown Wheel Bearing and Seal, by MikeP. Please note although this is for a K series the procedure is very similar
► Bevel bearing or paralever bearing ? easy check
► Replacing a leaking rear input seal on your bevel drive
Miscellaneous
► 1100 GS Granada Dakar register
► 1100GS Parts Lists and Exploded Diagrams Site
► R1150GS Fuel Gauge Repair
► Faulty ignition switch problem with 1150
► How to heat bearings/cases etc without using an oven
PM me if you want to add any links to this post :thumb2
