Mine was the same, thought I'd cured it by putting a jubilee clip round in place of the spring clamp fitted as standard. It still crept...
The hose isn't too short, it has a certain curvature, so it's not pulled tight by any means!
The black coating of the water pump housing is almost like teflon, so when the hose had 'crept' I cut a 1/8" strip of abrasive strip and removed a 1/8" strip of the black coating on the stub. It only took a couple of wipes with the abrasive strip to take the coating off and show the alloy... two or three drops of superglue, pulled the hose back over it and in to place and retightened the jubilee clip. Sorted... no more problems...
But then I've only done a hundred miles since
Will let ya know
Will let ya know
