Just a stupid question for tech gurus - is it pointless to double-seal the gearbox input shaft?
Last time I replaced it I remember there was enough depth to put 2 seals inside with a little gap. Crankshaft's output has 2 radial seals on later 1100s to decrease clutch's "contamination" and is a hell lot better design than the older 1100 that had only 1 seal and people had a lot of problems so I wonder if putting 2 seals for the gearboxes input shaft is a similarly good idea or not? I.e. if the internal one fails, outer will go on for some time.
Mine leaks like hell now (thank God I have Siebenrock's oil-proof clutch, otherwise I'd already be stranded for days in the middle of Mauritania with an unrideably slipping clutch
). Yes, it's done around 100 000 miles since I put the new seal, but it's PITA work and with no guarantees, so I wonder if double sealing would decrease the unlucky odds.
Also does anyone know if some common cars have similar measurement shaft seals? I need to find a replacement seal here in Nouakchott (ordering something from Europe will be very expensive)
). Yes, it's done around 100 000 miles since I put the new seal, but it's PITA work and with no guarantees, so I wonder if double sealing would decrease the unlucky odds.Also does anyone know if some common cars have similar measurement shaft seals? I need to find a replacement seal here in Nouakchott (ordering something from Europe will be very expensive)
