1100 'squeek' from engine mountings ?
The Other PaulG
Still searching
Surrey, England
Hi
I'm just keen to know whether this is something that needs addressing urgently, or at my next service.
Symptom - only occurs when the bike is started from cold, when the throttle is blipped (at a standstill) I hear a squeek from the front of the engine. It sounds like a dry metal on metal noise and co-incides with the torque twisting of the engine.
After riding for a couple of minutes it disappears and does not return until re-starting the engine from cold once again.
My guess is that it's an engine mount that's somehow allowing movement around a metal to metal contact, and which 'nips up' when warm.
Any ideas?
Thanks!
Paul G
PS Please, no ABS suggestions....!:D
OK - I'll dive in first...
Sounds like classic alternator belt noise - whip the plastic cover off the front of the engine and check condition / tension.
There aren't any 'engine mountings' as such - the engine is a part of the frame (sub-frames bolted on front and rear). I think if something was that loose, you'd have more problems than just a squeaking noise - however, no harm in checking them for tightness (you'll need a hex / torx bit on an extension bar and ratchet).
Great, yes I've done that on a previous bike, dead easy. I'll have a look, no harm in changing anyway...
My 1100 does it too and it's a new belt on mine, the adjustment is fine so I just ignore it :)
Paul G (the other)
Thanks Paul -
OK so it's looking very likely that it's the belt.
That's fine, a spare is easy enough to carry and I'm glad it's probably nothing worse.
I couldn't bear the thought of being the first ever 1100 to have something go wrong with it... he he! :thumb2
PG
