1100gs techlusion connectors
bart2181
birmingham england
hiya,been doin a bit of business with a fellow tosser and i now have a techlusion r259 at hand,unfortunatly its for a 1150gs and i own a 1100 gs so the lambda sensor connectors are different:augie,any idea how i can wire this beauty in.the two lambda sensor connectors have 4 wires in each,3 connecting each other and 1 which runs to the techlusion,i,m thinking if i leave my lambda circuit has it is but dis-connect the lambda to ecu wire i can then wire in the tech ecu wires in their place?question is does that make any sense?which wire from the lambda sends the signal to the ecu?now i could just sell it and buy one which is made for the bike but that would be boring and at the moment i,ve fook all else to do so any help much appreciated cheers :thumb
My advice:
ask this question on ADVrider.. you're more likely to get an authoratitive answer from the americans as their 1100s came with a CAT as standard... I would imagine there are very few 'import' GS's in this country.. and even fewer that will have been messed about with in this manner.
My own had the whole CAT gubbins removed a few years back.. and now looks like a 'proper' UK model.. rather than the german import it in fact is.
