Cook1e
OK, did a search, nothing conclusive or informative...
Question - is my fuel pump dying, or is it something else?
Up to now, fuel pump has "whirred" normally for a few seconds when switching ignition on. Otherwise, I don't hear it.
Changed fuel filter at last service, about 1,000 miles ago. No problem.
Had tank off this weekend to get at electrics to fix heated grips, apply ACF50, etc.
Didn't do anything with fuel tank. It only had a couple of litres of petrol in, mind (usually I forget and fill the bugger up a few miles before I need to hoic the tank off, but this time I planned it
Finished what I was doing and put bike back together. When I turned ignition on, fuel pump gave a very loud whine for the same few seconds as it used to whirr for. The bike started and ran fine.
Now it gives this loud whine every time on switch-on, but it runs OK. A few times when I was riding this afternoon, just about 50 miles to Hornsea for fish & chips (and back), I noticed the same loud whine for a second or 2. BTW Whiteheads - probably the best fish and chips... ...in the world.
So, it's not the filter, unless it's blocked up very suddenly and unexpectedly.
It seems unlikely to be anything I've done, unless it sucked some air in, being a nearly empty tank it may have swilled about a bit and uncovered the pick-up pipe when I was removing/re-fitting it. I would expect an air bubble to clear itself though - yes?
However, something's happened, co-incidentally or caused by something I don't realise I've done. I don't want to be stranded, but neither do I want to replace a good pump unnecessarily.
Anybody had similar?
PS, yes I did search, so I know about the Audi 80 pump and also that it's a fairly easy job - I will swap the pump if there is any doubt, but I would be sick as the proverbial parrot if the new one made the same noise
