1150 no lights/indicators or horn
flatdog
Havant - Hampshire
Morning chasps
done a search here for faulty wiring but so much stuff comes up I cant find anything relative to my symptoms.
I'm 150 miles away from home,:toungincheek and need to get back today. no tools and no workshop manual.
As it says in the thread title, realised on the trip down yesterday (dry all the way)that these are not working.
bike starts and runs fine, brake light works when applied, but nothing else, no horn, indicators, main, dip or back lights work.
all fuses are ok, when the horn is pressed you can hear its relay clicking, jiggled wiring from ignition no flickering or sign that wires have broken in the loom.(loom is not tied to the frame - headstock area)
I.m on line for the next 2 hours so if you see this thread after 11.00 am i wont be here. thanks Flatty
The horn and lights are on different fuses so separate circuits. Best bet would be a connector somewhere that's come apart, either in the vicinity of the fuse box or under the tank, on top of the steering support casting.
Does the indicator relay click? Most likely it does (as the horn one does) but the broken connections are elsewhere, after the fuses and relays. Someone else may be able to say more exactly where there's a connector block that feeds the horn, lights and indicators but under the front of the tank is my best guess.
