1150 wiring diagram
PW Cymru
Moderator
Moderator
Nr Cardiff
Has anybody got a scanned copy of the 1150 wiring diagram they would be willing to e-mail me.
A red lead taking +/- 14 volts to anything that needs it.
A black lead to bring the left-overs back.
For things more sophisticated - get a 1200 Canbus :thumb
I have a PDF wiring manual (pictures showing loom routing and the diagrams themselves) for a 2000 model - not a lot changed on later bikes. PM me your email address if you want a copy.
Thanks guys, I think I have all the info I need to really cause some damage now.
I appear to have an intermittent break in one of the horn cables, just need to do a couple of continuity test and replace the damaged cable.
Many thanks for the diagrams.
Looks like the earth return wire off the horn is broken, should be an easy fix.:thumb
Routing
I'm renewing my loom and have got the subframe back on, but I forgot to notice if the loom goes under the battery tray on the left or above it?
Which is it, as it's very tight under?
Anyone have any photos of the left side with the tank off. The diagram on the PDF file is not clear
