Maybe the banner at the top of the page should be changed, remove the photos and list the correct oils for all models of GS instead.
An oil is a substance that is in a viscous liquid state ("oily") at ambient temperatures or slightly warmer, and is both hydrophobic (immiscible with water) and lipophilic (miscible with other oils, literally). This general definition includes compound classes with otherwise unrelated chemical structures, properties, and uses, including vegetable oils, petrochemical oils, and volatile essential oils. Oil is a nonpolar substance.Just what exactly is "Oil" ?
The term oil is often used colloquially to refer to petroleum![]()
Jees!! If I'd have known I'd cause this much trouble i'd never have bothered asking!
Thanks to most for your helpful replies (particularly motobiker, good advice given).
Now sourced some 20/50 at areasonable (non-BMW) price.
. Most of it is well intentioned, often has nothing to do with you and after a bit you'll see where its coming from. Do a search on Oil, for example and you'll see the fun and games that has been had in the past on this topic.
I note you are from Wiltshire. A mate lives just south of Swindon, he has found the same problem finding oil other than 10W/40 in Swindon.
wait till u ask about the gearbox and f/d oil![]()
......theres a little red light that indicates its time to put oil in, just like the little orange one that indicates its time to put petrol in.
I have a friend who goes to the local garage too, and takes the bucket loads of black oil off them - he pours it, filtered through a funnel with a gauze in it, nothing more, into the FUEL TANK of his diesel car. He has been running this cars engine on old engine oil for nearly 70,000 miles now...for free.
Every now and then he puts a tank of diesel from the pump in, just to flush everything through. I love his fuel bill, but cannot bring myself to put old engine oil in my old Merc. He is driving a Peugot of some small denomination. Amazing. Easier than the chip oil dodge too.
ASDA 20W50 £6 for 4 litres.
Or pm Tarka for more details.
Or RTFM
Castrol do a 20/50 for motorcycles, GP I think its called. Have a look in your manual and youll see that differeent weight oils are reccomended for different ambient temperatures. When its hot like now in England or in a hot country use heavier weight oil like 20/50. If you were using your bike in lapland then go for a lighter weight like 10/40 or so. Having said that you will notice that the reccomendations in the manual have such a big crossover spec that its not so important. Quite a few people, myself included like a heavier oil like 20/50 cos it seems to make the engine a little quiter. I would find one oil of decent reputation and try and stick to it. Best of luck old bean ......![]()
