1150R gear changes....
adventuredon
Wandsworth, London
ok, new to me so still getting used to the bike. Lower gears are clunky, yes its a BMW thing. I get that. Having owned a GS in the past, I am no stranger to "positive" gear changes. This takes it to a different level though. At least once a day I hit neutral going from 1st to 2nd.
Often (esp when cold) it feels like it its hooking (technical term :)) between leaving 1st, neutral and then into 2nd. Hard to explain, almost like a door that has sunk on its hinges and needs lifting before it'll close.
If I ride to end of the rev range in 1st, the change is infinitely easier.
I almost run out of ankle movement, like its too far between gear changes. The rest seems okay. the occasional missing a gear also happens now and again. At speed, clutch less changes are smooth (up only mind). Bike is booked in for a service in near future but is there any adjustment that can be done, aligned etc? Are there any signs/test that can be looked at before just replacing/rebuilding a gear box? Ideas, suggestions, information welcome. Positive gear changes recommended can go jump....:thumb
The changes on my 1150R are probably the best of any boxer BMW. I have owned, not even a clonk into first, so there must be ‘good ones’ out there👍
My R1100GS was the same ,think the previous owner had adjusted the gear lever up as I felt as tho I had to lift my foot up to get it into higher gears , so I adjusted the gear lever rose joint thing 1 complete turn down , gear changes are nice now and no missed gears .. :)
might try that. but it definitely feels like it doesn't slot in perfectly either. Almost like its hesitant to leave 1st for second! Wish I knew more about gears etc to explain in more technical terms. Apart from the gap, it just feels like a snag somewhere.
Might have something to do with the different footrest hangers you’ve fitted ... and whoever revs out in first gear before changing into second on an old 1150 boxer engine :D
No. It was the same before the swap. I only ride a little bit higher in the revs to maybe 3k. I am still riding it like the GS. Change out of first ASAP. 1150 seems to be able to cope more in first, in traffic, than the GS could
I was told by an old Beemer rider that to change gear smoothly on a BM you have to put weight on the gear lever BEFORE you pull in the clutch, then it will slide in with no clunk. So this is what I have always done since - you deliberately select a gear rather than 'snick' one quickly like you can on a Japanese bike.
Whether this is true or not I don't know any better - but certainly on my 80 and 1150 the weight on lever first technique results in perfectly smooth changes, but if I pull the clutch first and then use the stick, it clunks.
Dismantle, clean & grease the lever pivot and linkage.
Then put it back together, natch... ;)
What he says :thumb
The lever pivot and linkage go all dry ... it's like paddling with wellingtons on :D
Do this anyway, regardless ....
And don't pull the clutch all the way, if you're doing this you only need to use about a quarter or third of the lever travel...nice and smooth :thumb2
Well, loaded it a lot more today before changing. Didn't miss second once...greasing etc will be put on Steptoe's service list....!
You've been riding BMWs for how long? And pre-loading the lever is a new thing for you? I thought that's what you meant when you eschewed advice re 'positive gear changes' :blast
