Now it's time to split the crankcase and see just what state the crankshaft is in. Again it came apart really well with no excess force required and no signs of previous mechanical violence. Fingers crossed!
The camshafts are really good, E3134 on the exhaust and E5048 on the inlet. No wear lines or ridges at all. (ignore the raised numbers, they are just casting numbers, the actual part numbers are stamped in. This causes quite a bit of confusion when sourcing parts)
Now for the all-important bit, the crankshaft. I took one conrod off and couldn't believe the condition of the bearing shells, they were perfect!
I looked on the back to check the size and there was nothing except the part number - E3586, which is the standard size bearing. Surely the crankshaft couldn't still be at it's original dimensions after 60 years???
I checked the bearing journals and they looked perfect. I then measured them, 1.6235" which is standard size, unbelievable. (the picture shows slightly less, when measured with the micometer held properly they are 1.6235")
