2003 1150gs no battery light
lacedr
essex
my recently acquired project has passed its mot and is roadworthy !
unfortunately the battery and neutral light do not work and i cant remember if it worked or not when i first got it!
the alternator is charging battery good there is power to the bulb 12v but no light. when i put the tank back on yesterday connected up then turned the ignition on it came on but so do the low fuel light albeit very faintly, kicked up the side stand and off they went again.
all earths cleaned and good including earth on the alternator.
any ideas where to look cant see any obvious damage anywhere.
recent new battery
gear indicator works
help!!
Blue wire to alternator?
take it off and ground it with ignition on
Light comes on ? Wire and that circuit good
Path to earth through contact and brushes is suspect
Should be charging at 14 ish volts
Charging ok
Ground blue wire no light
Guess I am going to start looking for a fault with that wire
Go to the Bulb first! and change it for a known good one
Bulb all good.
Stripped all the outer sheath off and one wire wasn’t connected so Cut back and re soldered the wires back together all good now neutral light and battery light back on.
Thanks for the replies
