Kenoath
Hi all, new on here. I would appreciate some advice if anyone has had a similar issue.
I have a 2015 F800GSA that I took delivery of about a month ago. Km is a bit high at 100k but it was a 1 owner bike in very good condition, and the owner had a record as thick as a bible of everything he has done, including tyre changes and average fuel economy. It was also 40% cheaper than the nearest other F800GSA.
It ran flawless for the first 500km. Low and high speed, traffic and open road. It stood for a week as the weather has been utter shite. I started it up yesterday and about 2km down the road when I twisted the throttle to pass a car it bogged and misfired. I tried again, same story. I limped to the next place I could pull over, stopped, revved the bike and all seems fine. Rode about another 15km and no problems.
The bike switched off for about an hour after I stopped, and when I restarted it the misfire was back but even at idle. After about 5-6km limping home it all but disappeared. First start up this morning and the misfire is there immediately. Tried revving it etc, to no avail. Right hand side exhaust is much colder than left.
I stripped the bike, swopped the coils and same symptoms, now the left hand pipe is cooler than the right. Bike wasn’t covered for the first 2 days and got rained on. I had a cover on it from day 3. I don’t see any signs of water close to the plugs or coils, but have sprayed everything excessively with electrical contact cleaner.
Before I replace the coil, has anyone had something else they would recommend I look at? Or go through an extensive fault finding process and replace parts that aren’t faulty? TIA
