2021. 1250 shaft failure
Thread closed - the expert has spoken.
Chains belong on bicycles...ridden little girls or gays wearing Spandax...:D
This is how crazy this forum is..."Shaft failure" and the rubber boot came off...Happened to me once.15 min fix on warranty ! I take a driveshaft over a chain any day.Change the reardrive oil / 180 ml every 6 k miles and the shaft/reardrive will give you 100K miles of reliable service...Yes if you run wash-board off road I would take a chain as the constant shock-load will kill the U-joints.But that is just commons sense a lot of people lack nowadays...
Read the thread , it wasn’t the rubber boot that came off and it was the OP that called it shaft failure because “ the splines gave way “ at low speed and he appeared to lose drive from what he said.
Are you homophobic?
Straight men and women wear Spandex - it is important to have a good physic of course!
Oh bugger, I went out in rainbow striped cycling gear today as I thought I must be gay after his post.
So it seems I’m not, the wife will be pleased.
