I used to use Halfords own brand ...
And it was about 13 quid for 4 litres.
That's the ½-price offer they have from time to time.
Greg
Can I use WD40?
It's got a 'W and a '40' in the name. I normally use 10W40 so what's the difference? - they both seem very slippery.
You can because the 'D' stands for dunce![]()
& the fact we are talking dry sumped pretty basic design etc.
What is the sensible answer, I know this will probably have Steptoe slapping his forehead in despair, but I would like his considered opinion, if he is prepared to give it one last time & I will follow the advice with a promise never to read an oil thread ever again.
The definitive answer is within your grasp- No arguments or counter claims,or accusations of being an idiot - It's all in the bikes handbook.
Factors in heat dissipation are the surface area and the temperature difference. If the ambient temperature is 20°C and the radiator water temperature is 90°C, you'd need a cooling area of twice the size than if the oil radiator was 160°C.
We're not!
Greg
...and I think you'll find that it isn't the correct spec for a GS....![]()
this is the 2006 2nd edition handbook page.
i believe 20w50 is what is now recommended by BMW, so i think my duckhams 20w50 API SF/CD is OK.
my dealer uses castrol GP which is 20w50 SG
Well that is very clear - for all round use in the UK 10W40 is best. If you go abroad and the temp is likely to be above 30C then use 10W50.
20W50 isn't the best all round grade for the UK because the temp frequently goes below 0C (unless of course you never ride in Winter).
It ain't rocket engineering!
What you`re missing is that 10w40 is specced for -20C to +20C and UK ambient temperature does actually exceed +20C.
20w50 is specced for -10C to over 30C so is still a more suitable range.
You may need 10w40 in extreme low temperatures,but the -10C protection of 20w50 covers most eventualities,at least in proper,civilised,non rural areas of UK.![]()
Besides....20w50 cures more rattles.![]()
if i was over there - and i was a bit anal about it - which i'm not - i'd be using
10w-40 for winter
20w-50sg for summer
in reality i used 20W-50 all year round
http://www.leroybeal.net/motorcycles/silverwing/articles/oil-filters/Motorcycle%20Motor%20Oil.pdf
