dancata
Hi all,
Recently pressure washed my bike, to identify an oil leak - it was the oil pressure switch.
Right after that, bike was running ok, took a short ride and everything was normal. The day after that, it only runned for 50 meteres, then stopped :|
Checked for error codes, and nothing appears (have done this other times, it should say 0000 or 4444 for ok status, but this time, the LED stays lit, does not blink). I have checked HES, they are ok, I am sure of that. Fuel pump is ok, I can hear it when ignition on, and can smell gas coming from the exhaust when trying to start, so I think this means injectors are ok too.
Today I checked the spark plugs, and I have no spark! both sides. Next step was the coil, and that one is ok - it measures 1 ohm for primary coil and 13kohms for secondary coil - does that sound ok to you?
Any ideas?
Thanks,
Dan.
Any ideas?
Thanks,
Dan.
i feel for you dude
