AA Breakdown/Recovery
sherpatensing
Cambridgeshire, England
I had the misfortune to breakdown whilst using my 1952 AJS 500, with a broken throttle cable. The AA patrolman duly turned up 20 minutes after my call and I queried where the motorcycle trailer was, as he would not carry a spare cable. He then took off the twistgrip, found a small piece of drilled brass in his toolbox and soldered this on the cable. As we were a bit unsure how secure the soldered joint would be, he followed me home (about 10 miles) to make sure all was good. Pretty good service I think.
Amazing but you seem to have announced this in the non-WC 1200 'technical' department.
Yes, as we already had an earlier thread regarding our experiences of the various breakdown/recovery companies, I thought this may be of interest to the contributors of that earlier thread. With hindsight, I perhaps should have found a more suitable section.
Good to hear that some breakdown patrols will still actually try and fix things rather than just tow you.
But I guess your AJS is the right bike for that sort of fix - I'd bet you wouldn't have been so fortunate with a 1200...
(See the effortless way I got the thread back on topic for the section? :D )
Bicycle gear cables do a great job for throttle cable inners on older bikes much smoother running than the stiff carbon steel originals. Soldering the end nipple needs the right solder flux.
I've been recovered by the RAC three times and by BMW also twice. My standard RAC cover only gives me 10 miles to the nearest dealer which was ok, but I was lucky. The BMW cover was much better: both incidents were some distance from civilisation and once the bike was at the dealer I was offered a taxi or a loan car to get home. I'm not sure if this cover is part of the extended warranty but however you get it it's excellent.
