casperghst42
Hi,
Started the bike after a rest stop earlier today, and ABS was flashing (triangle off) at 1hz , decided that I wanted to go home anyway (was in Belgium), and the ABS light went off when I pulled away - as it should do.
I got home, and did a test, turning the ignition on while holding the ABS button in will stop the flashing, but if I turn on the ignition without holding it in it will flash....
As far as I understand the ABS light will continue to flash if there is a problem (and yes I can break). I had the FD changed last week, could they have messed up the ABS sensor?
I'm confused.. I'll take it into the dealer next week....
Casper
Casper
