surreygraham
MOVED TO HEX HEAD FORUM
On approaching a line of stationary traffic I applied my brakes as usual and all was fine. Suddenly the brakes appeared to fail and to avoid the stationary queue I was forced to move into on-coming traffic and was nearly killed. I managed to stop using 'manual' braking once I knew I had to apply more force!
BMW diagnostic showed up a failed ABS Modulator which, looking on line, seems to be a common fault which requires an expensive repair. To my mind the inherent danger posed by this particular failure means that BMW should be recalling affected bikes and repairing them FOC. I called a supplier of used parts today and he told me that he gets daily calls for this item.
My family nearly lost their father and I want to make sure that nobody else is nearly, or actually, killed.
So, I have joined this forum to try and find out the level of likely support for a Watchdog type campaign. Are there any fellow GS riders who are interested?
