BMW have done retrofits on most things for year and years... the fact they sell the loom kit must mean you can have the heated seat coding retrofitted - sure dealerships are lazy and incompetent and prefer to tell you to go away rather than help...
Go see the parts department and ask them about ordering the FSC for the heated seats. Option code S0518 SA Seat Heating - I expect it will be circa £120 - if he can order it, the clunky joke of retrofit coding gently turns over - within 24 hrs Germany will have updated records for the bike and then the numpty in the workshop can plug the bike in and it allows the automatic coding of your bike - once done you can check your VIN on a decode site and find post build options sit out of order at the bottom of your VO list
Although they might be funny - I expect this coding can be done without the parts on the bike - it shouldn't care at the time of programming - all they are really doing is adding that Option to the VO which allows the canbus insanity to do things wrong, and tick a box so it shows up in the cluster menus - you'd hope aftermarket kit could turn this on - but Motoscan doesn't do VO tweaks, and GS911 may have an issue on the R1300 - the world has moved on this era of bikes - it gets a "Secure access gateway". This stops people just doing what they want. I fully expect this tweak needs an online handshake with Germany to get it done
