flytoolow
Well, following on from a previous post, I successfully removed my alternator (and dismantling the ABS in the process)
Now I replaced the Voltage regulator and found that the resistor on the old regulator was missing - Im assuming that this was the problem since the alternator wasn't charging.
So, Now I have the alternator on the bench. Is there a simple way to test the alternator before I reinstall it ? I can spin the alternator using a model aircraft starter motor, but which is the energising terminal etc ??
