And so it’s Starts 🤞🤞
Hi folks hope you’re weekend went well 👍
While we’re contemplating whether the motor on the D1B1 is ok to fit, any advice on how to join these little beauties, I’ve read somewhere about liquid electric stuff but for the life of me I can’t remember (a)if that’ll do the trick,or (b)it’s a load of rollox 🤔
Cheers Baza
Motor now sourced, and spins like an ice skater on steroids 😉👍
Cheers Baza
Hi all, now I’ve got the new motor on the bench a couple of Qs
How d’you hold the pegs back while putting the little bearing in 🤔
And is it possible to test the motor when it’s in the Ali housing before it’s fitted to the bike🤔
Cheers Baza
Cheers Baza
Okay there is a "Knack" to this
You need a brill bit that is CLEAN AND NO BURRS on the smooth shank
I think it was an 8 mm but its been a while
Fit the Bushing on the drill smooth part And what you have to do is just "Learn the knack" it may take a few goes
Insert and rotate the bushing at about 45 ish degrees to the surface and push and rotate the whole drill bushing thing around, it will hopefully pick up one and open it and then spread both the plungers by the third revolution and just drop in
A little grease in the bearing side of the bushing and insert motor and secure it
It is better to have the pipes all plumbed and primed with fresh fluid before Plugging it in to test it !
You "may" need a GS 911 or motoscan to completely bleed the brake system
I think a video of this method would be very helpful at this juncture 🕺
Cheers Doc,I’ve got a Motoscan but I reckon I’m a while off using it yet 🙄
What was your take on the D1B1 motor🤔
No idea what it is to be honest :hide
If the bushing fits between the pistons and the motor casing fits down into and between the raised sides of the ABS block and it is 12 volt?? It should in theory work
BUT I know that the Mk 7 fiesta one works Absolutely
No need for YouTube fella’s I had a Eureka moment, my turn to pop something into this forum 👍
I tried Docs trick and couldn’t get the hang of it, but while having my tea, bingo Feeler Gauges 🤔
Piece of Piss two minutes and it was sorted, Jeeez am I pleased with myself 😇🤣
Easy suggestions on how to clamp the bugga down,not forgetting I’ve never done any taping out before 🤦‍♂️
Cheers Baza
It twas a slightly bigger casing then the Ali was knocked over on four sides 😉
Cheers Baza
I mentioned to the Doc about using Araldite on an earlier post,and he said NO, fair play,
but what about J D WELD,the reason i'm saying resin,is because i'm not sure how far you can drill down
the Alloy block,and where i can drill,,,,,,,,,,,,,Cheers Baza
right at 2 of the corners 10mm deep and tap out to M5
You are only holding that shape down into the alloy "edges"
You can;t use epoxy as I very much suspect that it will break free with heat cold vibration and would NOT be my chosen method of restraining a spinning motor that has an eccentric boss pumping brakes!!!
The photos might explain it better Doc, when you say drill the corners I take it you’re referring to the raised corners as ringed in RED.
As you can see by the first picture the light grey motor (the new one) is slightly smaller than the Black one (the old one)
Cheers Baza
Morning folks, so I’ve got my drill and tap kit,but I’m not to sure about what I’m doing, the Doc said “ 2 of the corners 10mm deep and tap out to M5”
But as the rough photo shows,it’s only threading the hole about 5mm, so does that mean I only need a 5mm bolt to hold the motor down,couple of questions how hot does the motor get, and how fast does it spin,
taper tap and a plug tap
you start gentle with the taper (the one in your pic) - then usually finish with a plug tap - but you really want a bottoming one for a blind hole
various bodges to get it to stay there
must be lots of meat on some look at the length of these ones
I let these guys do mine years back
