Bear
Last Sunday I had the red triangle plus the brake failure lamp flashing fast while riding. This was at the end of a 150 mile day, with no prior problems. I switched off the engine, waited a few seconds, then restarted it and all was well. Sixty miles went OK yesterday. I has the same thing twice today. The first time I restarted the engine and the fault went away. The second time I didn't bother trying. As far as I could tell the front brake still has servo-assistance but the rear hasn't while the error shows. At home, I checked that both brake light switches work OK (they do) and that none of the pads were worn. All seemed OK so I took the tank off to check the reservoirs tucked away underneath. Assuming I checked the correct items (10mm allen key to open them and DOT4 brake fluid stamped next to them) the level in each seemed OK. I had the rear wheel sensor out about 1500 miles ago to change the FD oil but since the speedometer still works I cant see it as a problem. I'm now stuck for ideas until the dealers open on Tuesday so any suggestions would be gratefully received. I should have said at the beginning that the bike is a 2006 1200 with servo-assisted ABS.
