Aoocci C6 Pro
OSMAnd supports Apple CarPlay but OutdoorActive doesn’t unfortunately. I’m not too sure about the same apps on Android Auto
OSMand definitely supports Android Auto. Not sure about the other one though. I like OSMand but would say this........if you find Garmin Basecamp a challenge you are going to hate OSMand :D
A question about the mounting of these units.
Is the mount like, say, a garmin XT where you just remove the display unit and leave the electrics behind, or something else?
Got the 3D bracket printed today and it works well and holds the C6 pro perfectly.
Thanks @NeilGS for the fast shipment of the mount.
Just of note to other Hex R1200GS Adv owners - The nav bar seems to be a bit thicker than newer models and a bit of tweaking (sanding) was needed to get the mount parts flush with it. The two parts don't touch but it's a nice solid clasp and I don't foresee an issues.
Also, if you're not replacing existing mount then you will need to get some nuts and bolts to secure.
I have bought a C6 Pro to use with my 2024RT. I am thinking about fitting above the TFT screen on a stick on satnav mount from Nippy Norman . Has anyone any experience of this or advice?
I cant see a pic in link but i used a stick on mount for my tom tom on my RT with no issues. Mine had a ram mount ball and used a short arm onto my tom tom.
Thanks for that. I was wondering if the adhesive was up to the weight of the device but I guess it will be similar to a satnav
  • Like
Reactions: Doc
Have you fitted this yet? I am going to do the same I think and wondered how you got on.
I haven’t fitted it - I’ve sold the C6 Pro deciding not to go that route. However, I do have the mount on order from Aliexpress and will use it to fit my Garmin XT
Fitted mine to the 1290 Adv. Cracking bit of kit. Lots of cables to run to make a neat job and as I'm Mr Neat, it had to be done. I bought a metal bar/bracket that sandwiches between the main KTM screen and its mounting bracket as well as the bar amps mount from Alibaba £25 total. It's rock solid.... not like the KTM screen mount. Excellent result so long as its reliable. I get to use MyRouteApp which is a joy to use. Waze to spot professional cameramen. IMG_4330.jpegIMG_4335.jpegIMG_4333.jpegIMG_4336.jpeg
This site also sells the Aoocci C6 Pro, and it seems like a great deal.
Same deal as many bloggers are offering with 22% off .
I just ordered another using LCR22 for same deal
A quick survey,
Has anyone had any working issues with Aoochi yet? Appreciate it's not hot weather, which would probably show up any issues more.
