Autocom - Zumo problem
BILLSKI
isle of wight
I have just fitted a Zumo and already have a Autocom pro avi. The problem is when i get to about 35mph, i get a sort of interfierance noise that sounds like wind noise and the sound coming from the Zumo Music/directions, cant be heard as it tends to go really low. If i slow down a bit the wind noise stops and normal service is resumed. Another problem is that when i went to start the bike tonight. there was no sound at all coming from anything, Zumo was working all Ok but no sound. Stopped the bike, turned every thing off and still no good. When i turn on the ignition the Zumo says that it will revert to battery power in so many seconds, is this right? Is the Zumo working properly with the canbus. After a couple of tries of turning on and off it started to work. There are only 3 bars showing for charging on the Zumo, i thought that it would always be fully charged if its wired direct. Any help would be appreciated. :nenau
Assuming the Autocom was OK before you fitted the Zumo, have you upset the setting of the Vox control during the installaton.
Have you used isolated leads or Bluetooth to connect the Zumo and Autocom?
