Aux 1 power on autocom active plus
jondprice
Cambridge
Hi,
Does anyone have the instructions on how to enable the power to aux 1 so I can use the Bluetooth dongle? Thanks
Thanks Mick, I can't see a switch anywhere on the unit. I think my unit is an early one before they had powered aux 1 as standard. I read somewhere that this can be done by soldering a wire on the circuit board but cannot find any instructions on how to do it.
You'll probably have to take the lid off - look for a screw or screws under the main sticker by rubbing your thumb over it. The power option is likely to be a jumper rather than needing soldering, in which case it will be a very simple mod. Unfortunately, as you have found, there isn't much info about how to do this on the web.
Have a chat to Sam at Chainspeed - he knows his Autocoms and should be able to help you out.
Yea have to agree Sams an expert with the older systems and he is ex Autocom himself. His number :- Tel: +44 (0)1994 484428
Thanks for your help, I'll check it out when I get home from work and then call Sam.
Is this what you mean?
The 2 little "grommets" on the end pull out.
You must connect the plug from the opposite end of the Dongle into Aux 1 only.
Simple to do...just done it :D
From the advrider thread, it looks like it's not a jumper swap after all. If you have a problem with the soldering, drop me a line, you're less than an hour away.
