Perhaps you need darker raybans , my point is, if they catch your attention, job done, they will not be in your eyeline for long.
A great post Warlord. Hopefully everyone will take on board your sage advice.I've got 6 lights on the front of my GSA. They will bring down aircraft when all fully on.
However, they are also controlled by HEX EzCan device.
My BMW OEM 'Fog Lights' are rarely (never) turned on. These really are only called into action on pitch black night country lanes.
My Auxilliary Spot lights are on at 10% power during daylight and dipped beam. They are ideal as DRL's.
On main beam they go up to 100% and are very bright.
I never ride with main beam on.
Study has shown it is very difficult to determine speed and distance when dazzled with oncoming headlights. You are better of on dipped beam and lateral movement. Triangle lighting is good.
Also search 'fighter pilot study on the effect of saccades' People really don't see you so take more control and SLOW DOWN.
It certainly looks like a well adjusted rig but I miss the triangle shape in your setup.
Or so I'm told.... What he said.Fuck there is some piss poor attitudes in this thread. Don't whinge when you dazzle someone with your lights and they come directly into your path you morons
What he said.
I set mine up parked behind the wife's car she was pointing out the point where I was fully lit up but with good visibility in the mirrors. Strangely enough they were not angled up in anyway. When I tested that line she said it was extremely distracting and could not work out any distances. This took about 5 mins in all, and probably saved drivers getting pissed of with my aux lights.
Sent from my SM-G930F using Tapatalk
Never mind all the bollox with the lights, what dashcam are you using that gives that display? Does it have to be especially wired in to the bike???
I like it.
MM
The chap following you seemed to have an interface between his additional lights and his indicators. If an indicator was on, then the additional light on that side went out for the duration it was flashing.
How do you achieve this?
All info in this thread
http://www.ukgser.com/forums/showthread.php/446846-HEX-ezCAN?highlight=hex+ezcan
