Balljoint rubber boot
ChrisH Kerry
Co Kerry
When I was changing the front tyre ready for an impending trip to Europe I noticed the balljoint boot is split... joint itself appears to be OK, so as it's unlikely I'll get it fixed before going should I bung a bit of waterproof grease into the boot or some other remedial measure?
If the rubber is in otherwise good condition put some grease in,clean the split edges thoroughly, de grease the split faces and stick back together with superglue. It sticks most gaiter rubber just about as well as it sticks flesh!
John
I have a spare here if you need. Should be with you tuesday if I post monday morning
As far as I know you can only buy the boot with a ball joint complete, we have found a small universal Car one works:beer:
Thats good. They are $114 on the US web sites which is where I get most of my parts info from.
It's not the cost of the ball-joint that's the problem, it's getting the old one out of the fork-bridge that's a real bastard.
Here's mine when it split:
The constituent parts:
I even managed to track down the company that makes them in Germany, fired off a request to buy a replacement boot and was informed that they supply the motor industry only, they have no capacity to sell other than in bulk.
I found a suitable replacement in the bin of a friendly car repair garage.
