Bendy toy
For about £5 you could wire in a digital voltmeter and velcro it to the dash/tank side panel.
if the Zumo is plugged into the accessory socket pull the plug out and see if the problem goes away.
If your multimeter is measuring 1ma on a scale of 2000ma I would normally doubt it's accuracy. A discharge rate of 1ma seems pretty neglible for a battery that must be around 11ah. Have you measured the self-discharge time: how long it takes to lose charge when the battery is totally disconnected from everything?
Sorry if this is a stupid question, but is there anything at all connected to the Canbus power sockets?
If the alternator is not turning then, regardless of the ignition being on or off, I don't see how it can have any volts across the output terminals unless there's a fault with the regulator/rectifier.
I said that in post 25 with the diode pack comment.
Check the wiring for chafing as that may well give similar symptoms. It's common alongside the battery and easier to look there than taking the petrol tank off.
