Bloody Battery Again!
Santa-2512
Omnipotent one
North Pole
After spending a wonderful evening fitting my new lights, and ensuring they worked.
using them for no more than 10 mins operation on high beam
Rolled the bike out this morning, prodded the starter button, and all i got was a clunk
Tried again, and the same... FFS
Grabbed the jump battery and hooked it up, gave it 30 sec, and pressed the tit.
Span straight into life.
Ran it to work, all seems ok, although the idle did have a bit of a flutter when i stopped
It was a cold night, with temps near on freezing , so yes that could be a factor.
But..
Brand new battery - 3 months ago, not top of the range, but nevertheless new
Starter has been stripped / cleaned and brushes ok
Additional +ve to battery direct
Additional -ve to battery direct
No other indications of problems...
Before i go and spunk £100+ on a motobat or Oddesy
Any thing else that could be the cause of this battery problem?
I was thinking of hooking up a meter and seeing what current drain is comming off the battery..
Would the new LED Lamps be causing it?
Mart
Mine does that sometimes if I try to start it before it's gone through the check sequence
Came out this evening,
Pressed the tit, and away it went...
ran home fine ...
I'm going to put the gs911 on it now, then the meter, then the optimate
battery's lol
Mart
GS911 run and falults as follows
ABS - no shit sherlock :)
Headlamp main beam - open circuit
Headlamp dipped beam - open circuit
Sidelight - open circuit
Battery voltage reported as 13.01 volts
Popped the multi on for drain check
Voltage 12.83 after powering off, picked back up to 12.84 left monitoring for 25 minutes dropped to 12.81
Ive put the optimate on it , it was reporting 13.23 - will leave for a few hours to give a boost ..
Strange!!!
Need to measure the current drain with everything off.
Voltage alone gives little info.
Ok how do ido that ??
Mart
You disconnect the neg lead to the battery - set your meter to 10 amp range and put it in series between the battery neg and the neg lead.
Search YouTube for parasitic draw and there are videos showing how
