NorthernBoy
luckylucian said:ABS only kicks in when you brake hard enough to lock up the front wheel
That is simply not true. It is how it ought to work, but not how it does work.
Often, when I have lifted the front a little (and only a little, not a big wheelie), the ABS is in full effect on what is moderate braking on a good surface.
I have also experienced less conclusive examples, such as where normal, slightly firm (not emergency, panic, or a real handfull) braking on a rippled surface has brought it in. This is a level of braking that I simply do not believe would lead to lock-up. I am talking easing down to a junction from 30mph. Something that a drum-braked bakelite-tyred FS1E woudl do with no drama.
The system makes mistakes at the moment.
