Brake fluid renewal
Spud
Fylde England
My 2002 (non servo ABS) 1150 is due a brake fluid change.
Is there anything I should be particularly aware of or advice that I may need before attempting it ?
Probably time to change the hoses too!
Yes if the hoses haven't been changed get some braided ones fitted. The bleeding process is a simple on on a non ABS 1150. I'd suggest if you've not already done it bleed the clutch at the same time.
I took OP to mean he has ABS, but they're non-servo?
If so, these videos might help?
1/2:
Don't drink brake fluid.
As above :D
I think that it's a case of bleeding at the ABS module first and then the corresponding circuit..match the nipples :rolleyes:
Lines are already Braided, and I promise not to drink the stuff :jager
