Calculating using Long/Lat point
Mike Werner
Cloggie amongst Frogs
Normandy, France
Nothing to do with riding, but if I've got a Long/Lat position, how can I calculate all points in a database say within 30 kms from the Long/Lat position ??
If you sort of ignore the fact that the distances per degree vary over the face of the earth..
find out in mapsource what 1deg is vertically and horizontally as a distance.
Get an absolute value for the diffence in each coordinate, multiply by the no.s you worked out per degree to get a distance, square both, add them, square-root, and there's your approximate distance. 30km shouldn't have too much of an error in it.
On-call !
You really are bored aren't you !
The circumference of the earth is appox 40,000,000 metres.
Each degree of latitude is, therefore, about 111 kms.
Each minute of latitude is about 1,850 metres (approx 1 mile)
Each second of latitude is about 31 metres.
It's a bit more complex for longditude.
At the equator: Each degree of longditude is, therefore, about 111 kms.
But at the poles, each degree of longditude is zero distance.
So the general formula for longditude distance is:
Degrees of latitude from the equator/90 x 111km per degree of longditude.
QED
Greg
Hmmmmmmmm. Thanks. Going to be a bit on the difficult side, but I'm going to give it a try.
Never been good at math.
