Cameleon Chain Oiler
Alan R
Cumbria
I've been considering fitting an E Scotoiler to my f800gs but have been unable to find a satisfactory (to me), place to mount the metering device.
I have just found this Cameleon device which uses an ingenious method of storing the oil in a flexible tube that is capable of being routed around the bike frame. It is a gravity feed system that uses an electronic metering device that fits neatly to the bike frame http://www.cameleonoiler.com/en/products#kit
Has anyone fitted such a device? If so, what do you think?
Alan R
So, it seems no one has bought one of these devices. By the weekend I will have one and will see how it fits and performs.
Alan R
Received the unit today. It's really neat and small - the metering unit fits in the palm of your hand and will not be difficult to fit to the frame tube commonly used for Scottoiler location. The reservoir tubing will be hidden either forward under the dummy tank bodywork or rearward under the seat. Just need to decide where the dispensing end of the delivery tube should terminate - at the rear or engine sprocket...
I may produce a photographic fitting thread if I find time.
Alan R
Received the unit today. It's really neat and small - the electronic metering unit fits in the palm of your hand and will not be difficult to fit to the frame tube commonly used for Scottoiler location. The reservoir tubing will be hidden either forward under the dummy tank bodywork or rearward under the seat. Just need to decide where the dispensing end of the delivery tube should terminate - at the rear sprocket or at the engine sprocket...
Alan R
